VCR Noise problems? (1 Viewer)
DeathStar1
Neil
Sorry I can't get much more specific than this, but it seems as if after two years, my VCR's start to develop a high pitched ringing noise whenever tape playback happens, never during recording. If needed, I can try and record a sound sample of this noise to try and help identify it.
If anyone knows what I'm trying to describe, LMK, and here's hoping it's an easy fix :).
Thanks!
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Hi Neal,
I’ve never heard of a hi-fi VCR doing this. Is this an old VCR? They had linear audio tracks that were very prone to this ringing noise.
If your VCR is late-model then I suspect it has a problem that will probably require a trip to the shop.
Wayne A. Pflughaupt
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Just thought of something – don’t know why I didn’t think of it before.
Go into the menu and look for an “audio monitor” setting. The options should be something like “Hi-fi,” Normal,” and “Mix.” Make sure it is set to “Hi-fi.” The “Normal” setting engages the linear tracks, which (as I mentioned) are prone to make this kind of noise.
(The “Mix” setting engages both options simultaneously and does some really weird stuff.)
Wayne A. Pflughaupt
Reddevil_23
