VCR\DVD combo problem, please help!
Discussion in 'Archived Threads 2001-2004' started by BradVan, Jan 16, 2003.
  1. BradVan
    BradVan Auditioning
    Jan 16, 2003
    11
    I am new to Home theaters and am actually going to purchase some equipment soon. Here is my problem: I currently have a DVDVCR combo player and was wondering if I can hook it up some way so they both work with the surround sound. I was told that if I connect the DVDVCR to the reciever with an Optical or Coaxial digital cable, that my VCR won't work and I would need to get another one. Is this true?
  2. Carl Johnson
    Carl Johnson Cinematographer
    May 6, 1999
    2,259
    25
    Carl III
  3. BradVan
    BradVan Auditioning
    Jan 16, 2003
    11
    Thanks for responding Carl, but the guy I talked to said I would need another VCR. Is this possible? He was a salesmen at radio shack. I am just trying to determine my budget, and I really don't want to purchase another VCR if it's not necessary. So if anyone knows how to connect it so they will both work that would be great! I am really anxious to start getting some equipment and I don't want to get the wrong thing if there is some special jacks etc. I should be looking for. Thanks again guys.
  4. JayDaniel
    JayDaniel Stunt Coordinator
    Jun 11, 2002
    114
    Brad, this has nothing to do with your DVD/VCR combo, and everything to do with your A/V Receiver. If you have a surround receiver, then you can hook up your combo player to it to receive surround sound. Most combo players I've seen have different audio/video connections for each sub-component (i.e. one set of cables for dvd, another for the vcr). If that's the case, hook them each up to a different set of inputs on your receiver (a digital connection from the dvd is needed for DD/DTS, and composite/rca connection from vcr), and you should get Dolby Digital and/or DTS with your DVD, and Dolby Pro Logic from your VCR tapes.
    Hope this helps.
