Rob TT
- Feb 1, 2002
If my DVD player supports VCD, that meens it should play an mpeg 1 right?
If my DVD player supports VCD, that meens it should play an mpeg 1 right?i doubt it. mpeg1 is the video format for vcd, but if you put the vcd in a cdrom drive, you will notice the video is in the format of a .dat file, in the mpegav folder. so if i am understanding your question correctly, no it wont, at least i seriously doubt it. i am assuming you are asking if your dvd player will play mpeg1 files off a straight data cd that wasnt burned as a vcd. if anyone has any more info, please contribute.
CJ
