Is there any code that lets you move an image a bit to the right without any visible text to the left of it. This is for a thread I have been discussing with Parker.
Thanks.
Thanks.
The sample above, along with it's warnings, surely isn't all there is to it.
Uh, pretty much, it is.
If you know HTML code for tables- then you're all set. VB has no table code that I'm aware of, so you use HTML.
IF you want to post a test in the test area and send me a link, I'd be happy to check it out.
-V
