Vb Code For Signature... (1 Viewer)
AbelM
How do you add scrolling text to your signature? I want my text to scroll by in my sig instead of just sitting there. So can anyone help me out here?
I know there is a code for it something like [movetext]CodeGuru[/movetext] or something...please help!!
Thanx :)
Andre F
Might want to try putting the effect in a gif and then adding the gif to your sig...just a thought.
-Andre F
MichaelPe
Try this link: Link Removed
Actually, you may want to double-check with the mods before adding HTML tags in your sig.
AbelM
Wait...now I see the scrolling text, but how do I add HTML to something that is VB?
AbelM
Hey thanx Mike...you are right. Sigs can't handle HTML. So now I guess the only other way is the url you gave me. But how do you do it? What is the first step for...All of these options??? :frowning:
Thanx man, you have been a big help!
MichaelPe
but how do I add it to my sig now?
Well, once you see the animation, you can right-click it and save the GIF file somewhere on your computer. Then, you have to upload it to a webserver (check with your ISP to see how to do this). And then all you have to do is insert the image's URL into your sig with the
NHCondon
