Using XP Pro on AMD K6 processor (1 Viewer)
anthony_b
Has anyone upgraded to XP pro from 98se using an AMD K6 processor ?....that's what I'm using with 224 MB of ram.
Should I stick with 98se or should I perform the upgrade, and if so should I wipe out 98 or upgrade from 98 ?
Kelley_B
what K6 processor are you using? Personally I wouldn't run XP on anything slower then 500Mhz and 256MB RAM....even then it can be painful.
anthony_b
I'm using a 400mhz....should I increase my memory before I go ahead with it ?...Also, how much disk space does it use ?
KyleS
I too would not recommend moving to Windows XP with a processor slower then 500mhz (Minimum) and 256mb ram. I have installed it on a 450mhz AMD K6 processor and it didnt run well at all even after I set Windows XP to run as best performance, turning off all extras. My advice is to upgrade your processor, motherboard, ram, first before looking to go to XP. Otherwise it will be more frustrating then its worth.
KyleS
anthony_b
Yeah, after all the hardware upgrades, I'm probably better off bying a DELL P4 for $599.
SteveMc
I tried running XP on my thinkpad that runs a PII Celeron 366 w/256 RAM and it was almost un-runnable. Would click and wait 5-10 seccs to respond. Stick with 98 unless you get a newer rig.
Staff online
jebsib
