Using wall as a screen, what color paint should I use to yield best results?
Discussion in 'Displays' started by Inspector Hammer!, May 12, 2004.
  1. Inspector Hammer!
    Inspector Hammer! Executive Producer
    Mar 15, 1999
    11,061
    Houston, Texas
    John Williamson
    I currently own the Infocus X1 and for now I am projecting on a blank white wall, I have cream colored walls, but after installing the projector I beamed a 16x9 image from the AVIA dvd onto it, masked that area off and then painted a 96" white field on the wall to act as a screen. I also made my own black frame for the "screen" with ordinary poster board, which I am going to replace with sturdier foamboard this weekend.
    I'm also considering using another color for the screen if it gives me better results, improved contrast, black level etc...
    For those using your wall, which color are you using and why?
    I am aware that a real screen would be best, however I just can't swing that right now, so for now, i'm afraid i'll just be staring at the wall. [​IMG]
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Light gray works well with the X1 as far as boosting the black level and I have read reports of reduced rainbow effect as a result too. Others can post the exact paint colour.
  3. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    I am using comet gray on my wall. It is essentially the same colour as a stewart grayhawk. I am shooting 96 inches with a black velvet frame masking the screen.
    The projector is a Panasonic LCD AE300 and the gray wall gives me better blacks ...
    The wall outside the frame area was then painted ink black. coming into the room, one would be hard pressed to notice that I am actually using my wall.
    I put a 3'x3' sample of the grayhawk on the wall and it essentially vanished into the image. There is no decernible difference between the wall colour and the screen material.
    regards
  4. Parker Clack
    Jun 30, 1997
    12,215
    58
    Kansas City, MO
    Parker
    Michael:
    What brand of paint did you use and where did you get it?
    Parker
  5. Brian Fellmeth
    Jul 30, 2000
    789
    There is more information than you could digest in a lifetime on this topic in the screen topic at the AVS forum.
  6. Joseph Bolus
    Joseph Bolus Cinematographer
    Feb 4, 1999
    2,470
    207
    The "light gray" color actually works better with the LCD projectors than the DLP-based X1 in my opinion.
    Don't forget that even the "modern" LCD projectors struggle to get up to a 1300:1 contrast ratio spec, while the X1 provides 2000:1. However, the X1 is already "lumen challenged" when it's operated in either its "film" or "video" modes, and you therefore want *at least* a 1.0 gain surface for your screen. With a light gray painted wall, you'll probably end up with a slight negative gain. A negative gain works best with LCD projectors which typically provide far more lumens than the X1. With that kind of projector you're trading lumens for a boost in the contrast ratio. You don't have the lumens to spare with the X1, and the contrast ratio is already adequate. Go with a white color. (And don't forget that a light gray color on your wall is *not* going to emulate a Firehawk screen, which has specially formulated reflective properties.)
  7. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Comet Gray ... Home Depot
    Behr Brand.
    Colorant 0Z 48 96
    B Lamp Black 1/26/0
    C Yellow Oxide 0/20/0
    I Brown Oxide 0/8/0
    Regards
  8. Dan Stone
    Dan Stone Stunt Coordinator
    Nov 28, 2001
    221
    While not the least expensive solution, this certainly gives results which are quite a step up from your basic grey paint:
    www.goosystems.com
  9. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    It's a cheap low cost solution. If the goal is to match the characteristics of a grayhawk, then what would spending more give you if you cannot see a difference between the paint and the grayhawk already as it is?
    One can always spend more money ... and there is not only one solution to this. But at the ground level, you can get pretty good results for essentially $20 worth of paint.
    Regards
  10. Inspector Hammer!
    Mar 15, 1999
    11,061
    Houston, Texas
    John Williamson
    Thanks guys for the responses, i've made a note of your suggestions and am going to pick up the paint tonight.
    Thanks again for the help.[​IMG]
  11. Parker Clack
    Jun 30, 1997
    12,215
    58
    Kansas City, MO
    Parker
    John:
    Don't forget to use black for the frame of your screen and even the surrounding wall that your screen is painted on to. This will help make a huge difference in the way that your overall picture looks in the end.
    Parker
  12. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
    I second that as I have been through all of that already. I even framed my screen in a velcro-like material that absorbed light even more than the flat black paint I had prior...
    DIY screen closeup
  13. Mike Keith
    Mike Keith Second Unit
    Jan 24, 2002
    324
    I read a article that explained how painting your wall to mimic a Firehawk screen was futile, the Stewart Firehawk uses special reflective material that paint cant match. According to this article, painting with anything but white will decrease your brightness. I don't have any personal experience so I can't say for sure.
    Here is the article.
    http://www.projectorcentral.com/proj..._screens_a.htm
  14. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    According to the Stewart site, the firehawk has a gain of 1.35 ...
    Generally anything with a gain higher than 1.0 cannot be replicated with paint. (Goo maybe)
    So if you are trying to match a silverhawk with paint ... forget it as well ... ditto for all their many other 1.0+ gain screens.
    If you want to match a 0.8 gain Grayhawk ... then one of the paint answers is above.
    Regards
