Using SPL meter
Discussion in 'Speakers & Subwoofers' started by Jim Mcc, Jan 17, 2005.
  1. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    I'm thinking of buying a SPL meter to set my speakers and subwoofer. It seems the analog one from Radio Shack for $49 is highly recommended, is that right? Is it easy to use? Any tips for a first time user? Thanks.
  2. DougR
    DougR Second Unit
    Jun 15, 1999
    354
    Actually it's very easy to do !!
    Here is just one "How-to", of the many that are out there.
    Have fun !!Calibration with Radio Shack SPL Meter
    * Please Note that there Will be others with Variations to the Procedure. But the Basics are there.
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Yes, get the analog one. I had both the digital one and analog one for a little while. I much preferred the analog one:
    1) You can get down to 0.25 dB resolution if your readings fall near the center of the scale. You only get 1 dB resolution for the digital meter.
    2) The battery lasts longer in the analog meter. [​IMG]
