Using scart on a widescreen TV
Discussion in 'Archived Threads 2001-2004' started by Chris_Theuns, Nov 10, 2002.
  1. Chris_Theuns
    Chris_Theuns Auditioning
    Apr 2, 2002
    7
    I'm in the process of looking for a widescreen tv (76cm). After having a look at whats available I have noticed that most of them do not have S-Video or component video inputs but 3 or so scart inputs. Is there any difference from scart to the other two formats? My DVD player only has composite and S-Video outputs and I'm not looking to upgrade that in the near future. The clerk said that you can get a S-Video to scart leads. Will this result in diminished video quality?
    Any answers are greatly appreciated.
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    SCART jacks may be configured in different ways including S-video and composite. Check your manual to be sure your TV accepts S-video, then you can get a cable with an S-video plug at one end and a SCART plug at the other end.
    You should have no degradation of quality.
    Video hints:
  3. Chris_Theuns
    Apr 2, 2002
    7
    Thanks a lot for the advice. I'll keep it in mind.
