Using RCVR preouts to separate amps
Discussion in 'AV Receivers' started by Dan Sloane, Feb 18, 2004.
  1. Dan Sloane
    Dan Sloane Extra
    Feb 13, 2004
    23
    Hi everyone, this is a great forum. My ? is... If I use my rcvr preouts to a separate multichannel amp then can I also use the rcvr amps for rooms 2 and 3 with less demanding speakers. eg. Denon5803 or B&K507 with B&K 7870 or other 7 channel amp for main room with ML Aeriusi L/R, ML theatre C, M&K S150 for all the surrounds. Then a less demanding speaker for stereo in rooms 2 and 3 for less critical listening. Does this work?
  2. Dean_S
    Dean_S Second Unit
    Feb 4, 2004
    261
    I can't say for the Denon but that won't work on my Kenwood recv b/c as soon as I remove the jumpers from the pre-out/main in the internal amp no longer gets signal. I guess you could rig up a 'Y' adaptor with one end going into the main-in and the other to the amp to make this work.
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    Yes – the jumper feeds the signal into the amp. A “y” adapter would do the trick to feed an outboard amp and the internal amp at the same time. You’ll need a female to two males “y”.
    Wayne A. Pflughaupt
  4. Dan Sloane
    Dan Sloane Extra
    Feb 13, 2004
    23
    Thanks guys, I should clarify that I want to use the rcvr amps for zone 2 & 3 with different source inputs. I hope I am making sense, ie movie in the main room and maybe cd in zone 2 etc.
  5. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    You’ll have to have a Zone 2 output for that. It would route back into input of the vacant amp channels.
    Wayne A. Pflughaupt
