using RCA MM52110 as computer monitor..?
Discussion in 'Archived Threads 2001-2004' started by Dan_J, Jan 30, 2002.
  1. Dan_J
    Dan_J Auditioning
    Aug 26, 2001
    4
    Has anyone had any success using their MM52110 as a permanent monitor solution? Mine seems to work fine on standard desktop applications, but whenever I try to run Direct3D apps the screen is scrambled and I am forced to ALT-TAB (or CTRL ALT DEL if I am unable to get out with ALT TAB). It seems to be an incompatibility issue as I have gotten the same results on 3 of 4 systems. So far I have tested 2 Athlon-based systems using different variations of the NVIDIA GeForce 2 chip(the MX 32 meg and GTS 64 meg), a Dell Intel-based system with ATI 16 meg Rage 128, and a much older Intel-based laptop with an older video chipset that I cannot recollect. Of the 4 only the laptop was able to run anything other than standard desktop apps without becoming garbled. If anyone has managed to successfully set up their MM52110 to avoid this problem could you possibly post a reply as to how you did it? Thanks.
    -Dan
  2. Dan_J
    Dan_J Auditioning
    Aug 26, 2001
    4
    bump
