LeeH
- Jun 1, 2003
I was wondering (after looking at the specs) if you think it would be a good idea to use 3 peavey cs-400 (or cs-800) amps for running the speakers. The cs-400 is rated at 120 watts rms into 8 ohms and 200 into 4 ohms at less than 0.03% THD with a frequency response down to 20hz. These amps are huge. They way around 40lbs a piece. Do you think it would be a good idea?
