Using equalizer and optical cable with cd player
Discussion in 'Archived Threads 2001-2004' started by ace peterson, Aug 23, 2001.
  1. ace peterson
    ace peterson Second Unit
    Jun 4, 2001
    340
    Just wondering if anyone knew of a way I could use my equalizer at the same time I use the optical(digital) out on my CD player? I have a Denon 3200, an Onkyo equalizer, and a Sony CD player.
    I have the equalizer going through the 'monitor source' on the receiver and it works great if I just use regular RCA plugs out of the CD player. But, I wanted to try to use an optical out cable instead and the Denon manual says the monitor funtion doesn't work when using a digital-in signal...
    Is there a better way I could hook up the equalizer and still use the optical cable?
    Thanks in advance for any advice.
    Ace
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,310
    89
    9,110
    Corpus Christi, TX
    Wayne
    Sorry Ace, you can’t “mix and match” digital and analog audio signals.
    Wayne A. Pflughaupt
    My Equipment List
