Using Dishnetwork Oval Dishes with Direct TV
Discussion in 'Archived Threads 2001-2004' started by Lanny Hoff, Apr 1, 2002.
  1. Lanny Hoff
    Lanny Hoff Stunt Coordinator
    Dec 20, 2000
    59
    I'm the proud owner of a complete pile of garbage Dishnetwork Displayer and I'm completely fed up with it.
    The satellite dish I've got on the roof is an oval bugger and my question is this: can I use the dish and the LNB units from my Dishnetwork gear with Direct TV?
    My thinking is this: I'd like to re-orient the existing dish to the Direct TV HD feeds and normal satellite programming, use the hardware that is already on the roof and just change the receiver. Can it be done?
  2. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,296
    52
    9,110
    Mississippi
    If you have a Dish500 (the 20" dish) then you may be able to use it. If it has two dual LNBs, that's OK. If it has the wider Twin or Quad LNB, then those aren't compatible. None of the Dish switches are compatible if they start with "SW-"
  3. Lanny Hoff
    Dec 20, 2000
    59
    Your information has been helpful. Thanks a lot!
