Using city watermain in place of sonotube?
Discussion in 'Archived Threads 2001-2004' started by David Giesbrecht, Jul 26, 2001.
  1. David Giesbrecht
    David Giesbrecht Second Unit
    May 28, 2001
    306
    Would this work or would it resonate badly.
    toughts? [​IMG]
  2. Jeff Blair
    Jeff Blair Second Unit
    Apr 30, 2000
    335
    That stuff is made out of PVC right? If it is, I wouldn't sugest that you use it. People here have said before that, that stuff isn't good for a sub. Just my $.02 and I might not be right. [​IMG]
    Jeff Blair
    Most folks are about as happy as they make up their minds to be.
    - Abraham Lincoln
    My DVD's
  3. Rick P.
    Rick P. Stunt Coordinator
    Mar 2, 1999
    63
    10
    If you're referring to something like Blue Brute, it should work well as long as you can get a good seal on the ends. I'd think that its resonance point would be high enough that it wouldn't be an issue with a sub. As for strength, it would be WAY overkill.
    I'd recommend using Sonotube because it's easier to work with.
    Rick
    [Edited last by Rick P. on July 26, 2001 at 05:24 PM]
  4. David Giesbrecht
    May 28, 2001
    306
    I went to pick it up today and decided it was way to heavy if I built my sub with it, it would probably weigh 150 pounds!
    Dave
