Using a Universal Remote with a Mit WS-65869?
Discussion in 'Accessories, Cables, and Remotes' started by Dan Hinson, Apr 6, 2005.
  1. Dan Hinson
    Dan Hinson Stunt Coordinator
    Jul 13, 2002
    113
    4
    Tennessee
    Dan Hinson
    Greetings,
    I have been trying to figure out the best way to set up a universal remote with my Mitsubishi WS-65869. I am also using a Pioneer Receiver for Audio.
    It would be grand if I could setup or program a macro so that one could push a single button and simultaneously change the TV input AND the video source on the receiver, but given how the Mitsubishi’s “NetCommand” menu, I simply don’t see how this would be possible.
    Sure, I could program a remote pull up the Mit’s device menu, toggle two clicks to the right, and then select DVD. But the problem is, that only works if I was watching cable TV. If I am watching over-the-air HDTV, and then selected the DVD macro, two clicks to the right would not land me on my Mit’s DVD input.
    If I had a cable box or even Satellite, either with options for HDTV, then I could simply route everything through an A/V Receiver (though I would have to get a new one that accommodates component video) and run a single video inputs into my TV from the receiver, thus truly making my TV a “monitor.”
    As it stands now, however, I am using my TVs internal HD tuner for over-the-air broadcasts, as well as the analog tuner for regular cable. Thus, changing video inputs on the Mit is a must.
    As near as I can tell, there is simply no way I can hit a single button and get my Mit to go directly to a specific input. …unless of course, someone out there can help, or simply knows something that I don’t regarding my Mitsubishi.
    Any help is much appreciated…
    Dan
  2. Dean_S
    Dean_S Second Unit
    Feb 4, 2004
    261
    I'd be surprised if the TV doesn't have discrete IR codes for the inputs (even if the OE remote doesn't use them). You might jump over to a universal remote specific forum and ask your questions there. Try remotecentral.com. Also, A harmony remote (activity based instead of device based) might work really well for you if the TV has discrete codes.
