Using a Pro Bass Amp...
Discussion in 'Home Theater Projects' started by Tom McGary, Jan 30, 2005.
  1. Tom McGary
    Tom McGary Auditioning
    Apr 21, 2003
    13
    I have settled on the Tempest in the adire designed EBS alignment. I have the 250w PE plate amp waiting, but I was wondering: I have a Carvin Pro Bass 500 bass head, which can go 500 watts bridged mono @ 4 ohms with speaker level outputs. Is it possible to use this in a home theater setting? I thought at one point I read about a voltage problem with consumer output (the sub RCA out) being too low for the professional 1/4" input. Anyone know anything about this? Thanks!
    Tom M
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Unless you can bypass ALL the preamp functions in the head amp this won't sound very good.
  3. Bryan_G
    Bryan_G Agent
    May 7, 2002
    49
    I once owned an rl series carven head, and if I remember correctly there was a way to completely bypass the preamp stage. I can't remember if there was a pre-amp in or if you have to put it in the return for the efx loop, but there should be something. If you can get it figured out it should work fine, its the same amp stage they use on their power amps.
    -Bryan
