Using a pair as a center
Discussion in 'Speakers' started by Paul Mor, Apr 3, 2005.
  1. Paul Mor
    Paul Mor Stunt Coordinator
    Aug 3, 2004
    82
    I'm thinking of using a pair of bookshelf speakers as my center channel. What's the best way to wire them? Thanks in advance for any help.
  2. LuckyB
    LuckyB Agent
    Mar 21, 2005
    27
    Why don't you just use one up front and one in rear?
  3. Paul Mor
    Aug 3, 2004
    82
    I've got a 7.1 hook-up...though my room, etc. don't allow it to be set up perfectly.
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    Parallel. One speaker to the next. + to +, - to -....
    I use dual Bookshelfs for my center. Works very well for me.
  5. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    John on always thought a series was one speaker to the next and parallel was dual wires from (center out in this case)amp to 2 speakers. Is this wrong.
  6. PeterK
    PeterK Supporting Actor
    Jan 14, 2004
    519
    no thats not wrong ryan. it's just that you can parallel hook up without having 2 different wires from the amp. Just as john said. positive to positive, negative to negative on both speakers. [​IMG] It is still a parallel setup. just condensed so to use less wire.
  7. PeterK
    Jan 14, 2004
    519
    Is hooking up 2 centers via parallel a wise idea? the ohm rating would be 4 assuming 8 for both speakers. this would drive the amp really hard and since it is the center channel it is going to be playing a LOT, during movies atleast. I have my rears hook up parallel but it isn't a big deal cause the rear doesn't play much anyway. If it does work though, what is the advantage of having two instead on one speaker for center channel? I assume this is just two bookshelves right beside eachother, not one on top and bottom. It isn't indicated in the OP
  8. John S
    John S Producer
    Nov 4, 2003
    5,460
    Limited advantage on having two for sure. In my case it was simple placement issues.
    And yes, it does represent half the resistance to the amp.
    One or two channels at 4 ohm still isn't like having all speakers ont he amp at 4 ohms. If you avr starts sutting down, discontinue the dual centers.
    I actually like having the exta power on my dialog channel though in all honesty though, but I set the dialog volume per source/content anyways.
  9. PeterK
    Jan 14, 2004
    519
    So is an advantage having less distortion at high volumes because the drivers have to move half of what one would? Is that why many center channels have 2 5 or 6 inch drivers so each one has to work less hard on those dialouge frequencies?
  10. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    OH ok I can picture that now. You just twist both parts of one strand together for the receiver but leave them separate for the speaker. I get it, sorry.
  11. John S
    John S Producer
    Nov 4, 2003
    5,460
    Maybe PeterK, I won't really say that, but never hurts having a little extra power for the dialog channel.
    Now the purists, really get rather horrified at the prospect, and you do the run the risk of actually hurting performance somewhat with two speakers producing a any mono signal due to cancellation issues, but in the end, you need to let your ears decide I suppose.
    Works well for me though, I use what would be considered near field monitors with my setup.
  12. Phil Iturralde
    Phil Iturralde Screenwriter
    Oct 7, 1998
    1,867
    Or just wire them In-Series, which will be an easier load for your Center AMP since it doubles the ohm rating. (8 ohm + 8 ohm = 16 ohm)
    Once you REFERENCE Calibrate your AUDIO, it's all fine!!!
    FYI: I have my two Rear Center Channel Speakers wired In-Series since APR 2003 - works gloriously up to REF LEVEL!!!
    Phil
  13. John S
    John S Producer
    Nov 4, 2003
    5,460
    You could do series as well. I'd sure try parallel first though.
  14. Eric Hargrove
    Eric Hargrove Stunt Coordinator
    Nov 24, 2001
    153
    John and Phil both have valid points. A 4 ohm load will indeed give you more power output provided the receiver is 4 ohm stable (most are). The only downside would be the additional heat created and the reduction in damping factor. The 16 ohm load Phil proposes would be very easy to drive but at only half the power of an 8 ohm load shared by 2 speakers.
  15. drobbins
    drobbins Screenwriter
    Dec 2, 2004
    1,872
    110
    Dave
    When I completed my theater, I found myself looking at my center speaker when someone was talking, not the screen. I added another center above the screen to bring the dialog back in to the screen. They are 8 ohm speakers and are wired in parallel. So far after 2 months, no problems[​IMG]
  16. darrylCHER
    darrylCHER Stunt Coordinator
    Oct 28, 2004
    62
    Perhaps a better center channel speaker would be a more appropriate "fix"?? [​IMG]
    Darryl
  17. Paul Mor
    Aug 3, 2004
    82
    thanks for the help guys.
    Darryl: I like your idea best, but my HT budget is limited and my wife doesn't see a need for anything new, so I'm waiting a while to get a good center. I have Polk LSi 7's, anybody have an opinion on whether I should hold out for an LSiC or just get a Csi5. About a $200 difference and it seems a better chance of finding a Csi5 either on sale or used.
  18. Eric Hargrove
    Nov 24, 2001
    153
    I have used two Lsi7 speakers is series as a center channel while my LsiC was being repaired(due to my own stupidity) and it actually was pretty impressive. I think it was better for dialog than the LsiC due to the two Vifa XT tweeters. You would have to wire them in series as they are 4 ohm speakers. A Csi uses a totally differnt tweeter, drivers, crossover etc and would not be timbre matched to your Lsi's. I used a CS400 center briefly with my Lsi setup. Although the CS series is very good, it sounds different than the LsiC.
  19. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Each one doesn't work less, both work the same, and the result is a +6dB gain in SPL for the frequencies covered by those drivers by adding the second driver, making the speaker more efficient, though the x-over network will compensate for some of that to match the level of the tweeter and to get good response on and off axis.
    I setup my g/f's system using 3 LSi7s up front and I just used one for the center. The other was just a spare until my brother picked up a set, and now the "extra" is being used as his center. I would not recommend running two 7s parallel unless you have a pretty stout amp.
