Using a computer for a Home Theater system?
Discussion in 'Playback Devices' started by LawrenceT, Jun 12, 2004.
  1. LawrenceT
    LawrenceT Auditioning
    Jun 12, 2004
    Hello All: I am thinking of building a computer for a home surround sound system instead of using the traditional reciever. I already have most of the computer hardware, but I'm having a hard time finding decent speakers. I been looking at the Logitech Z-680, but they may be a bit small for my room (25'X25'). Any suggestions or ideas would be appreciated. Thanks
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Unless you are on a very tight budget, it's much preferred to use a traditional receiver and speaker/sub system hooked into your computer. It's what many many people do. Computer speakers, are well..... you know....[​IMG]
  3. Jeff Martin
    Jeff Martin Auditioning
    Jun 10, 2004
    10
    Actually the Z-680's are very impressive. Not something I'd use for a dedicated theater though.
    I agree with Chris. Use a normal HT receiver and speaker set up.
    Also make sure you get a nice sound card with an optical or coaxial out. Otherwise whatever receiver you get will be useless while using a 1/8 phono-RCA patch cable.
    Video card I'd recommend something with a DVI monitor output of course.
  4. Jeff Martin
    Jun 10, 2004
    10
    don't know how that happened....sorry
  5. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,461
    338
    9,110
    Cees Alons
    Jeff,
    Your second identical message (hit 'Submit Reply' twice?) is now deleted.
    Cees
