Using a 6.1 Pre-out in a 7.1 set-up??? Can this be done??
Discussion in 'Archived Threads 2001-2004' started by Mark Leiter, Nov 7, 2001.
  1. Mark Leiter
    Mark Leiter Second Unit
    Aug 9, 1999
    387
    I am currently upgrading my system to incorporate rear centers. Due to available funds I intend to use a less expensive pre-out for the time being until i can afford to Pre-out I really want.
    The problem is that this receiver only has line outs for 1 rear center speaker. I am getting two rear centers maited with two mono-block to power them.
    Since rear center signals are a matrixed surround, can I use a signal splitter to split that single line out into two lines then connect those lines to both my rears?
    Mark
    Mark F. Leiter
    My 1995 Corvette is for sale. Please view the web site I have set-up if you are interested.
    www.corvetteforum.net/c4/mark_leiter
  2. John H
    John H Second Unit
    Nov 27, 1998
    472
    quote: Since rear center signals are a matrixed surround, can I use a signal splitter to split that single line out into two lines then connect those lines to both my rears?[/quote]
    Yes, a Y-adaptor can be used to split the signal.
    Bedroom Based Theater
    [Edited last by John H on November 07, 2001 at 12:37 PM]
  3. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,989
    9
    110
    YUP, that's what can be done.
    ONCE, I CONSIDERED SPARING YOUR RETCHED LITTLE PLANET CYBERTRON, NOW.., YOU SHALL WITNESS IT'S
    DISMEMBERMENT...
    MY HT PIXS
  4. Mark Leiter
    Aug 9, 1999
    387
    Thanks, just making sure.
    Mark
    Mark F. Leiter
