using 6th channel on amp for subwoofer?
Discussion in 'Archived Threads 2001-2004' started by Jeffrey Chin, Apr 11, 2002.
  1. Jeffrey Chin
    Jeffrey Chin Second Unit
    May 22, 2001
    483
    this is regarding classe cav-150 6ch amp
    will 150w be powerful enough as the 6th ch for a sub?
    any thoughts appreciated
  2. Bob_L
    Bob_L Supporting Actor
    May 19, 2001
    891
    2
    Bob Lindstrom
    It would, of course, depend on the sub. But many subs would be driven to quite acceptable levels by 150w. I really don't know the specs on the Classe, though, to know what it has "in reserve."
    I believe the SVS guys have stated elsewhere that 150w will get solid performance out of their CS subs.
    Tom, Ron, are you out there?
  3. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    I've used that much power on my Shiva and Tempest subs with great success. The SVS subs should rock with that much power as well since they too are pretty effiecent.
  4. ling_w
    ling_w Second Unit
    Sep 3, 2001
    426
    You should probably bridge 2 channels of the Classe to get 300w into 8ohm. If you have a 4 ohm sub, don't know if that means it will put out 600w.
    Generally, I wouldn't recommend using spare channel of amp for sub, since with LFE, there is unusual demand on power which might not be easily heard. The other channels would still have to be on par to able to not sound strained if it is producing loud sound, or still sound refined if isn't.
