Using 4 OHM speakers
Discussion in 'Beginners, General Questions' started by sanjeev.sharma, Feb 16, 2004.
  1. sanjeev.sharma
    sanjeev.sharma Auditioning
    Feb 10, 2004
    3
    I just bought a Yamaha 5640. I was hooking it up with some old speakers I had lying around in the attic as the rear/center (from an old Fisher Pro Logic decoder). These speakers have an impedence of 4 OHM. The manual says I should use 8 OHM speakers for the rear and center. Can I do something here? Or just junk these speakers and buy new ones? The receiver cleaned up all my Home Theatre fund [​IMG]
    Sanjeev
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    2 channels, I'd say it will probably be ok....
    Try it, the reciever should go into standby mode or shut off if it truly does not like it.
  3. sanjeev.sharma
    Feb 10, 2004
    3
    Thanks John. I will try it. My Front speakers are 8 OHM. Just the rear and center are 4 OHM. Would this work?
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    You won’t know until you try it, sanjeev.
    Wayne A. Pflughaupt
  5. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    If you don't turn the volume way up, you can get away with 4 ohm speakers.
    If you connect two four ohm speakers in series (amp plus terminal to one speaker +, that speaker - to the other speaker +, the other speaker - back to the amp -) for each affected channel, the effective impedance will be 8 ohms and you will be fine.
    Video hints:
