Terry Watson
Grip
In Sydney for the first week F&A was shown in 70MM at Greater Union's George St complex in cinema #3, which at that time was the largest screen in Sydney. (Larger than Hoyt's cinema #7).It also had a season at the Astra in Parramatta, again in 70MM - the only time in this city that a film had a simultaneous release in the format. The image in cinema 3 was huge, but you are correct in your comment re the image. I remember thinking at the time that the 70MM clarity just was not there and the sound was somewhat underwhelming. Not a bad film but the presentation did not help its cause. Sadly when the company redeveloped the site #3 was "twinned" into two much smaller auditoriums - same fate that happened to the two largest cinemas in the Hoyt's complex next door.Terry Watson said:Then you were lucky. Many weren't as here in Sydney, it was shown in a relatively small theatre that had trouble holding focus. Howard apparently here for the opening thought the presentation good. I and many did not. Projection problems plagued the release perhaps because the format had not been used for so long and many theatres were using old equipment. F&A turned out to be a wasted opportunity which only did so so and no where near as expected. Result : no more 70mm.
