Used DVD Changers
Discussion in 'Playback Devices' started by AaronJawz, Mar 6, 2006.
  1. AaronJawz
    AaronJawz Auditioning
    Mar 5, 2006
    2
    I have the opportunity to pick up a used ONKYO DV-C600 DVD changer for fifty dollars. Just wondering if anybody has any info on this model, and whether or not anyone has any experienced with used changers. Thanks for the feedback
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Onyko's DVD players with the exception of the SP-1000 haven't been very good performers on the Secrets DVD benchmark tests. That's not to say the C600 for $50 isn't a good buy though as its likely well built and should sound good but there are better players available from an image stand point....of course they may be substantially more money even used.
  3. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,983
    6
    Unless it's for a childs room or a den that won't see a lot of action, then it's worth it. If this was for your main HT, I would pass on it. Touching on what Andrew said, there are great selections out there and they are not very expensive.
