Used Denon 3801 or 1803 or 1802
Discussion in 'Archived Threads 2001-2004' started by KelvinMc, Aug 21, 2002.
  1. KelvinMc
    KelvinMc Auditioning
    Jul 1, 2002
    12
    Don't know what happened on the first post???
    If you couldn’t guess from the title I’m narrowed by search for a receiver down to a Denon. I thought I had decided to wait on the 1803, but I’m not sure if I’ll use the rear center channel at my current house and if I was only going with a 5.1 setup I could just get the 1802. Well as I was looking through the local classifieds I saw a 3801 for $500. I figured that I might be able to get it a tad cheaper ~$475 or so, which will put it and the 1803 around the same price.
    Extra info to consider. I’ve pre-wired my HT room for a 7.1 setup, but the room is not finished yet and I don’t think a 7.1 setup would sound “perfect” in the room it will be in (another reason for a 5.1 system). Another thing is that I’ll probably be moving in 1-2 years and will drastically upgrade everything when we build the house we really want.
    I think I’m leaning toward the 1802 now just to save money unless I can get a really great deal on the 3801. What would you all do?
  2. Russell _T
    Russell _T Supporting Actor
    Aug 26, 2001
    579
    I think you can get a 2802 now from 6th ave for around $500.00??
