Use a Multiplexor -
Discussion in 'Archived Threads 2001-2004' started by Bob Monio, Sep 1, 2001.
  1. Bob Monio
    Bob Monio Extra
    Dec 29, 2000
    17
    David -
    I suggest that you not use a diplexor and go directly to a RF multiplexor unit. Channelvision makes a CVT1mini-11 that will cost you somewhere around $150. You can take the cable feed, split in the feed off of the mini-11 and you'll end up with the cable channels AND a channel that is your Satellite dish. In my home I have two receivers multiplexed in on channels 65 and 70. I used to have cable (since shut off) and it was running on the normal cable channels while the satellite was on the new ones. If they ever make an OTH for my dual-LNB dish, I'll diplex it into the cable - otherwise this configuration has worked very well. I purchased an extra couple of remotes and now 7 TVs can utilize the two receivers.
    (I know of people who have several receivers, their home security systems, cable tv, and other items all multiplexed into their home wiring systems. It may seem like alot for one of the units, but it definately is more viable for multi-unit management in the future.)
    Check them out at www.channelvision.com. Good luck.
    -Bob
  2. Bob Monio
    Bob Monio Extra
    Dec 29, 2000
    17
    Whoops. That was actually supposed to be a reply to David Ely's message. Please delete the thread, moderator. Thanks.
    -Bob
