Andrew S
- Sep 30, 2001
I wasn't happy with the sound (volume) I was getting out of my laptop when hooking it up to my receiver through the headphone output (I had to crank the volume to get any output on my receiver) so I bought a Turtle Beach USB soundcard with optical out, I thought it might fix that problem. I found I had more output, but there were these popping noises every couple of seconds. The soundcard has an optical and 1/8 mini jack, and the popping noise was still present when I used the mini jack. This is the same problem I had with a similar Creative USB soundcard I had tried before.
Anyone have any ideas on how I can eliminate this popping noise, if possible? Could it be my USB bandwidth or something like that?
Andrew
Andrew
