USB ports on Dell? Plus BenQ monitor (1 Viewer)
DeathStar1
Neil
Anyone know how I can get these working? I downloaded the monitor profile from windows update, and they still don't want to work. It's a 20" Widescreen model..
Also, anyone have the 24" Ben Q with HDMI? How well does it work? I'm thinking of getting this as my next monitor...also, does it have an optional speaker attachment for full HDMI connectivity?
Colin Davidson
Hey Neil -
Guess I am a bit confused about what your question is. Are you asking about the USB ports on a Dell monitor? Also for the monitor driver it should be downloaded from Dell not from MS. But I don't think the monitor driver has anything to do with the USB ports on the monitor. All you should need to do is connect a USB A/B cable from the monitor to a USB port on your PC. Your PC should then recognize the USB hub in the monitor and the ports should work.
As to the BENQ - sorry can't help you there.
Colin
DeathStar1
Neil
Ahh, OK. so THAT is how it recognizes the signal to the PC. Gotcha :). I'll give it a try in a few :).
ArtAD
