NickSo
- Jul 2, 2000
- Nick So
I just got a laptop, and im in need of a wireless adaptor...
Ive seen two kinds that would work, USB ones and PCMCIA ones... The USB ones seem to be cheaper...
I am planning to remove the network device normally, and only plug it in when i want to surf, because the laptop will be in my book bag, or in a laptop bag, and if its sticking out, im afraid if some pressure was applied to it awkwardly, it would damage the device and the laptop itself...
Is there much difference in ability to recieve a good signal reliably between PCMCIA and USB?
Would it be a good idea to spend a bit more and go with a more well known brand (I've seen the brand MSI often, are they a reputable brand? I know Dlink, SMC, LinkSys are the more popular ones)?
