USB Headphone Recommendations?
Discussion in 'Computers' started by Colin Davidson, Sep 28, 2003.
  1. Colin Davidson
    Colin Davidson Second Unit
    Jan 6, 1999
    403
    30
    Greetings:
    I am looking to purchase a set of UBS headphones for the PC. My current speakers, Altec 2.1's, do not have a headphone jack and I am pretty happy with the sound quality and output. I would eventually like to buy 5.1 or 6.1 speakers but the current location of the PC (kitchen) does now allow for a 5.1 arrangement.
    I read about Logitech's in the current PC Gamer issue and that is what got me going on this track. Looking for any recommendations, positive or negative on what I should consider. $100 is the extreme upper limit of the budget and would prefer to stay in the $40 - $60 range or even lower but they have to be good quality.
    Thanks in advance.
    Colin
  2. Ben.K
    Ben.K Auditioning
    Sep 28, 2003
    9
    USB? I'm not sure they make any decent headphones with USB connectors.
  3. JamesY
    JamesY Stunt Coordinator
    Apr 4, 2002
    174
    Personally, I use this (link and info below). It's just a simple switch, and the sound quality is fine, even from my Sennheiser 600's. There aren't many quality USB headphones worth their price, IMO. Just buy a audio switch/selector, there are other more heavy duty ones than this if you're worried about the sound quality. That way you can spend your money on regular/nicer headphones, which can be used with other sources...
    RadioShack 26-204 Computer Headphone Speaker Switch
    It provides a straight pass-through for your current PC speakers, while offering 2 inputs in the front for a pair of headphones and headset jack. I just use the headphone input. Press the switch and it routes the audio to your headphones instead of your speakers. If the link doesn't work, just search for Model#: 26-204 at Radioshack's website.
    Hope this helps...
  4. Matt DeVillier
    Matt DeVillier Supporting Actor
    Sep 3, 1999
    773
    as far as headphones go, get a set of Grado SR-60's. you'll thank me later
  5. Colin Davidson
    Jan 6, 1999
    403
    30
    James,
    Thank-you! I had no idea they had such a thing available. I looked at it on Radio Shacks site and they had a coupon for 35% off as well which means it's $9.99. Coupon expires today so I will be getting it this morning.
    Matt, I do have a pair of SR-60's that I will now be using thanks to James info.
    Greatly appreciate everyone's help.
