USB Connection
Discussion in 'Archived Threads 2001-2004' started by shaun_p, Jan 20, 2003.
  1. shaun_p
    shaun_p Extra
    Sep 13, 2001
    16
    Why doesn't all HT equipment connect together using USB connectors, each piece could have an in and out and all pieces are simply dasiy-chained together
    Would this work?
    Is this the way forward??
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Nice thought.
    USB is still fairly 'new' and there are millions of analog components out there that this new system would not be compatible with.
    And actually, USB is overkill for home systems. Something like Cat5 networking cable should be used so you can run it to each speaker. Then each speaker would have a network card, D/A converter and a mono-block amp.
    Meridian actually has a system like this, but it's in the $15,000 range.
  3. Brae
    Brae Supporting Actor
    Jul 25, 2002
    509
    USB does not natively offer any copy protection that is typically is being presented with either iLink or DVI connectivity solutions. What exactly would you like to carry across USB?
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i love usb.
    imagine plugging it your dvd player, the receiver detects it (and possibly auto-configurs itself) and you're done!
    still....i'm waiting for blue-tooth! no wires in a ht world - just imagine!
  5. Brae
    Jul 25, 2002
    509
    Hmm, you mean like how the VSX-49TXi and DV-47Ai via the firewire port?
  6. shaun_p
    shaun_p Extra
    Sep 13, 2001
    16
    I'm just thinking one single connection across the board does it all, surely you can't get any better than that!
  7. Brae
    Jul 25, 2002
    509
    That is the whole idea behind the 'i' models in the Elite line. It not only provides for management communication, but also the multi-channel data streams, too. One-cable solution for connecting the 47Ai player to the 49TXi integrated receiver.
    Not advocating, just using it as a prime example.
