Patrick Sun
- Jun 30, 1999
I will need to migrate a lot of data from old laptops to new laptops, and rather than get bogged down with setting up workgroups and using an ethernet hub or crossover cables, I would like to utilize the USB port of the new laptop.
So, does anyone know if there are 2.5" laptop hard drive adapters that plug into the USB port, and is read by the new laptop PC (running either Windows 2000, or Windows XP) just like another slave hard drive (similar to how Compact Flash/SmartMedia card readers work with USB ports)? TIA.
I'd ask the people to take out their old 2.5" laptop hard drives and pop them into the adapter and then attach it to the new laptop's USB port, and once the new laptop boots up, it should see the USB hard drive as another slave hard drive, and then it'd be easy to copy data from old hard drive to the new hard drive.
The reason for this solution is because I won't be doing the migrating, other people with not-so-savvy PC skills would be doing the migrating of the data from the old hard drive to the new hard drive at their remote location, so I can't offer hands on help.
