USB 2.0 Devices and 1.1 Compatibility
Discussion in 'Computers' started by Elizabeth S, Dec 22, 2003.
  1. Elizabeth S
    Elizabeth S Producer
    May 9, 2001
    4,685
    69
    4,110
    Hawaii
    Elizabeth S
    I have what is probably a very elementary question. . .
    I wanted to get a card reader and I have a USB 1.1 port. Planning ahead, would I be able to use a USB 2.0 card reader, though I wouldn't get the full speed benefit? Should every 2.0 card reader be backward compatible, or would it depend on the model?
    Thank you! [​IMG]
  2. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
    USB 2.0 devices are supposed to be backward compatible, they'll just operate at USB 1.1 speed.
    There are some devices that really need the USB 2.0 speed and wouldn't work well at 1.1 speed. But I wouldn't expect a card reader to be one of them.
  3. Elizabeth S
    May 9, 2001
    4,685
    69
    4,110
    Hawaii
    Elizabeth S
    Thank you, Wayne! [​IMG]
  4. Grady Reid
    Grady Reid Stunt Coordinator
    Aug 26, 2002
    133
    7
    10
    Olathe, KS
    Grady
    Saw this thread- thought I'd ask my own question...
    I have a couple of old USB 4:1 hubs from a few years back- before the days of USB 2.0. If I plug a USB 2.0 product into the older hub, will it transmit the data at 2.0 speeds or 1.1?
  5. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    IIRC, USB 1.1 at best. Unless the device has the USB Highspeed label on it, it'll operate at 1.1.
  6. Wayne Bundrick
    May 17, 1999
    2,358
    I agree. In networking terminology a USB hub has to behave more like a "switch" than a hub. If it's a 1.1 hub, then everything you connect to it will work only at 1.1 speed, and the devices will not even be aware that the hub's connection to the computer is capable of 2.0 speed. They will know only that they are connected to a 1.1 port.
  7. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Wayne,
    I just wanted to expand on one thing.. A Card Reader is
    certainly one of those things that you need USB 2.0 or
    Firewire on.. USB 1.1 on a Card Reader? Sloooooooow..
    I was running my USB 2.0 7in1 Card Reader on my USB 1.1
    ports and to transfer 56 Raw images from my CF Cards it
    took more than 30 minutes.. (My Raw files are 10MB each and
    I can only shoot in Raw [​IMG]
    Any of these 3+ Megapixel Digicams need a USB 2.0 if you
    are shooting in Raw, Tiff or SHQ Jpeg.
  8. Mark Paquette
    Mark Paquette Supporting Actor
    Aug 8, 1999
    519
    I have a cradle for my Phatbox MP3 player, which is essentially a 20GB hard drive. Anyway, the cradle is USB 2.0, but if I plug it into a USB 1.1 port on my PC it still works just verrrrrryyyyy sloowwwwww. 1 CD worth of tunes takes about 20-30 minutes over 1.1 and about 3-5 minutes over 2.0.
  9. Patrick Sun
    Jun 30, 1999
    38,749
    480
    9,110
    Well, the theoretical difference in throughput between USB 1.1 and USB 2.0 is 12Mbit/sec vs. 480Mbit/sec, so there's quite a bit of disparity in transfer speed.
  10. Wayne Bundrick
    May 17, 1999
    2,358
    I assumed by "card reader" Elizabeth meant a magnetic stripe card swipe reader.
