USB 1.0 or 2.0? How can I tell?
Discussion in 'Archived Threads 2001-2004' started by John B., Nov 5, 2002.
  1. John B.
    John B. Stunt Coordinator
    May 19, 1999
    54
    I have a pc w/ a usb port....I'm trying to figure out if it's the 1.0 or the 2.0 type usb....anyone know how I can tell? Someplace in the control panel? Thanks
  2. Arthur Legardo
    Arthur Legardo Second Unit
    Jul 21, 1999
    441
    Check the Device Manager if you are running Windows - it will say USB 2.0 explicitly. I believe XP (and maybe 2000) support natively USB 2.0.
  3. KyleS
    KyleS Screenwriter
    Jul 24, 2000
    1,232
    Do you know the manufacture and model of your motherboard, or if not when did you buy your computer? If you know the manufacture and model you can check their website but USB 2.0 has not been around for very long so if your computer is close to a year old or older then you can almost guarantee yourself that you dont have it.
    KyleS
