US XBOX output RGB signal ?? (1 Viewer)
Hello, folks.
My 1st post in this forum. :)
Does anyone know if US XBOX can output RGB signal ??
I live in UK, and own an US XBOX. wondering if I buy a RGB SCART cable for XBOX in UK, if it would work with my US XBOX.
Could anyone clarify this please ?
P.S. US/JPN GameCube does not ouput RGB signal.(Unless it's modded to output RGB signal.) Only European GameCube outputs RGB signal. But I've heard somewhere that US XBOX actually does output RGB signal. Thus European RGB SCART cable can be used with it.
Bjoern Roy
A friend of mine uses a german RGB Scart cable with his US XBox, so you should be fine. Its a cheap non-microsoft clone, though, because he didn't need the optical out on the MS RGB Scart cable.
mightyhorse
