Sebastian_A
- Sep 18, 2001
Hi fellow HTFers.
I am from Germany and own a US DVD Player (JVC XV-S65).
As you probably know, for the picture, it has component outputs as well as s-video and cinch.
I connected the DVD player to my television with an s-video cable (picture). Now, the picture clearly shows that this is not as good as DVD gets - I can compare it to a region 2 player that I can connect to my tv via SCART and the quality is BETTER - so, s-video is not the way to go.
Is there a way (i.e. an adapter) that I can use the component outs (RGB) and plug it into my tv's SCART input? (which is RGB ready)
How else could I achieve higher picture quality?
THANK YOU very much,
any help appreciated,
Sebastian.
Sebastian.
