US$80 AC filters... do they work?
Discussion in 'Archived Threads 2001-2004' started by David Susilo, Dec 15, 2002.
  1. David Susilo
    David Susilo Screenwriter
    May 8, 1999
    1,197
    I'm not here to ask for the merits of cleaning of AC power.
    The question is whether those US$80 Monster Cable and/or Acoustic Research powerbars with the supposed AC cleaning capability actually works or should I just forget about it?
    The budget will be around US$80 maximum.
  2. RussKon
    RussKon Stunt Coordinator
    Oct 31, 2002
    184
    the $80 units that you mention are basically glorified power strips...i would not rely on them for ac power conditioning or surge protection....
  3. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    If you're asking will they attenuate EMI/RFI over certain frequency ranges in your AC line by a given amount, the answer is sure. A variety of similar products exist as say the Belkin Isolators which can be obtained at Staples. At least in the Isolators, each pair of outlets has an EMI/RFI attenuating component to provide some degree of isolation from interconnected equipment. The further away the outlet is from the cord, the greater the amount of EMI/RIF attenuation. As to whether you've got a problem and as to whether your equipment is succeptible to whatever levels that may exist remains to be seen/heard. I wouldn't advise spending a whole lot on this type of technology and to simply stick to relatively established players.
