*Urgent* Please Help with Audio Setup *Need Advice*
Discussion in 'Speakers' started by HanzPerez, Feb 17, 2006.
  1. HanzPerez
    HanzPerez Auditioning
    Feb 16, 2006
    2
    I'm pretty new to the whole Home Theater thing and decided not to buy a Home Theater in a Box audio system. After a lot of reading and researching throughout this forum, I came up with the following setup for my home theater and I was wondering if someone who knows about this stuff can chime in with some help/comments/suggestions.
    My theater room is about 11.5'W x 11.5'L x 8'H and it will be used mostly for movies.
    Here's my system as of right now..
    Athena Point5 System MK II Surround Speakers System ($200)
    Dayton 10" Sub-100 125 Watt Powered Subwoofer ($125)
    Panasonic SA-XR55S Receiver ($230)
    And for the DVD player I am having trouble deciding between these two (if you can suggest one, that would be great)
    OPPO OPDV971H Digital HD-DVD Player ($200)
    or
    Panasonic DVD-S77S DVD Player ($215)
    Basically I just wanted to know what you guys think about this setup and if it would all go well together and be compatible. Any comments/criticisms/suggestions would be great.. Thanks!
  2. Daniel.Han
    Daniel.Han Stunt Coordinator
    Jun 6, 2003
    72
    Hey, Everything looks like a good system to start with and get into the hobby.
    I personally don't own the Oppo, but I have a friend who bought it and from the movies I've watched at his place it seems to be a decent player, it's small and the disc tray looks like a heavy DVD could break it off, but it has held up well so far.
    I don't know anything about the Panny so I can't make any meaningful comparisons.
    Good luck with the purchases and welcome to the forum!
    dh
  3. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Looks like a cool setup, the Athena/Dayton should be fine in that size space. I installed that receiver in my bro's system and it's great, intuitive setup and lots of switching.
    I have the Oppo 971, but I'd only recommend it if you're going to use the DVI output. If not, go with the Panasonic. What's your display?
