TarekZE
- Nov 15, 2002
I have an Integra DTR-8.2 receiver, B&W CM4 fronts, B&W CMC center and Velodyne SPL-1000 sub located in my relatively small living room/home theater room. I've been kicking around various ideas for surround speakers for a while now, ranging from wall-mounted micro-speakers to in-walls, but haven't been very enthusiastic about the potential deficiencies of either solution.
I was just reading on Dolby's website and the downloadable (PDF file) Crutchfield Guide to Home Theater, where they present the option of placing stand-mounted bookshelf-sized speakers facing UPWARDS behind the main viewing position (a loveseat, in my case). The Crutchfield guide maintains that this is a much better option in small rooms than in-wall or in-ceiling speakers, or where it isn't possible to place surround speakers on the sides.
Has anyone tried this or have any opinion on this technique? After considering all the other (limited) options for my small room, here's finally a surround placement solution that I think I can be happy with. If I do go through with this, I'd most likely be using B&W CM2s.
Also, is there anything I should be looking for specific to this application, in terms of speaker stands? I'm thinking of using Lovan 24" Affiniti IIs, which would make the top of the stand-mounted speakers about 5" below the top level of my loveseat. However, some problems I can with this is the top plate blocking the back port and wire mounts..
Any advice is appreciated.
-Tarek
-Tarek
