Karim Nogas
- Jun 30, 1997
I have upgraditis and am wondering which of the following would improve my system the most.
Currently:
Receiver: Denon AVR-3200
Mains: Mirage OM-10
Center: Mirage OM-C2
Rears: Mirage OM-R2
Sub: Mirage PS-10
DVD: Sony DVP-S500D
1) The DVD player is a second generation Sony. It’s not a highly reviewed item but it has done the job. It is used with a Sony 53XBR300 and produces a gorgeous picture. Sitting at about 13-15’, I don’t think a progressive scan player (even a Camelot which I was thinking at one point) would make a big impact. The only consistent problem is moire which might be helped with ISF calibration.
2) The 3200 doesn’t support DTS (it needs a Technics add-on). But with all the new sound formats, I was thinking about a Denon 5800 or 4802. But then that would mean I’d need two new speakers for the extra surround channel. I was thinking I could move my OM-10s to act as the surround L/R and the OM-R2s would act as the surround back L/R. I would then probably go with the new Mirage OM-5s for new mains. New loudspeakers and receiver would be the most expensive option.
3) The sub has also been considered a weak link although it has done the job. It has a 10” cone and internal amp. I had a hard time setting it up but I think I finally have it set right at 80Hz, LFE 0 dB on the Denon, 2 out of 10 volume on the sub and 9/9 max bass on the Denon. This produces substantial bass at reference level (0 db on the Denon) that shakes the room without hurting the listener or overbearing dialogue.
That being said, everyone is raving about SVS and I’m wondering if a “real” subwoofer (not that mine has done a bad job), would be a worthwhile upgrade.
4) Last, although I don’t know anything about separates, I’ve been reading and moving in that direction might be feasible. I was thinking about maybe using the Denon as a pre-amplifier and buying a 5-channel amp. Alternatively, maybe a couple of monoblocks to just power the mains.
I’m not looking to spend just for the sake of spending and saying I have another component, but want to see substantial improvement as I am pleased with what I have. That being said, let’s assume a budget of around $5,000 US.
Any suggestions would be greatly appreciated.
Thank-you
Currently:
Mains: Mirage OM-10
Rears: Mirage OM-R2
Sub: Mirage PS-10
DVD: Sony DVP-S500D
Thank-you
