Upgrading to Lexicon. Best setup method?
Discussion in 'Archived Threads 2001-2004' started by JackIR, Feb 20, 2002.
  1. JackIR
    JackIR Stunt Coordinator
    Nov 27, 2001
    57
    Well, I guess it was time to spend some $$$ So I decided to go from my 4 month old B&K Ref 30 to a Lexicon MC-12. I'm really looking forward to playing with this one. Are there any tips for setting up the MC-12? One good thing about the Ref 30 is that you could do the setup via software on your pc connected to the unit. That way you don't have to use the on screen menus. Does the MC-12 have anything like that? Also, can anyone suggest the best place to sell my Ref 30 other than Ebay?
    Thanks [​IMG]
  2. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Jack- I'm envious. [​IMG] The MC-12 is what I would get if I could afford it. (I'm getting the Logic-7 bug!)
    Quick question: I'm not as familar with their products.
    DC-1, DC-2, MC-1 (I think) ?
    If I just wanted DPL, DD, DTS, which one should I look at? (5.1 analog inputs would be nice too.)
    (I'm thinking I could get a good deal on something now, that I couldn't afford when it was new...)
  3. Rob Katofiasc
    Rob Katofiasc Auditioning
    Oct 3, 1999
    10
  4. Rob Katofiasc
    Oct 3, 1999
    10
    Kevin
    You should be able to pick up a used mc-1 for around $2500.
    Try http://www.audiogon.com/
    The MC-12 is the only one with 5.1 analog inputs.
  5. Will Gibbons
    Will Gibbons Agent
    Mar 19, 2000
    30
    Lexicons are reletively easy to set-up; the menus are pretty intuitive. You can download the MC-12 manual from the Lexicon site to give you a head start on getting ready for your new unit. The SMR site is a good one for Lexicon info. Have fun.
    Will
