ChuckW
- Oct 26, 2000
Hopefully, third time is charm! ) I have made two previous posts and only received two responses. I guess since I am new to HT I am not asking the right questions. So I will try one more once.
I currently have a Toshiba 36” TV 36A50. Sharp HTIB HT-DD5000, Sharp DB-710U DVD Video Player, Sharp VC-H813U Video Cassette Recorder and I added a pair of KLH TW-09 Satellite speakers as my “B” speakers. All this is in a 10’+ X 15’ room converted to a dedicated HT.
I purchased the above to put together an inexpensive system to see if this was something I wanted. I DO! Now it is time to build a better system.
I plan to upgrade the receiver first. These are the receivers that I have listed to check out:
Denon AVT-3802 (Because it gets a lot of recommendations here)
Marantz SR-8000 (Listen to and liked it)
Onkyo TX-DS787 (Onkyo recommended a lot here)
Pioneer VSX-36TX (Co-worker has one and recommended it)
Sony STRV-444ES (Co-worker has one and recommended it)
Yamaha RX-V3000 (Listen to and liked it)
I don’t really have a budget, but don’t want to spend more money that needed to put together a good HT given the limitations of the room.
Input and especially pros & cons to the above listed receivers would be greatly appreciated.
Also if anyone knows of a place to audition these with the same speakers in the Dallas/Ft. Worth area would be very helpful. I have been to a couple of CCs and some HT places near my work, but only one had a room setup where I could listen to different receivers with the same speakers.
Thanks in advance!
Chuck
Thanks in advance!
Chuck
