celsmore
- Dec 7, 2011
- Cory Elsmore
Hi folks, I thought my system was completely fine for my needs. Then I was at a friend's place who had a very nice setup (some higher end polk towers, a gigantic matching center channel, all in a very small room), and it got me thinking that I should look into updating mine. I currently have a YHT-395 system. It sounds pretty decent, but it doesn't seem to put out quite be enough for the reasonably large room it's in. We have a TV mounted over the fireplace, and the center channel placed directly below that. There is not enough clearance for anything much taller than the existing center channel. I can measure exactly how much I have to work with if that would be helpful. After hunting around here, it looks like my first priority would be front speakers with a matching center. I was thinking a pair of bookshelf speakers, along with a center channel, then eventually the bookshelfs could move to be my rear channels if I ever decided to upgrade to towers. My budget would be around $300 to work with now. I could certainly expand that eventually if I can't get anything much better than what I have now for that. Does anyone have an general recommendations for me, or see any gotchas with the direction I'm looking? I'm completely dumb when it comes to audio related stuff. I can plug in the wires, follow the placement guides and such. At the end of the day though I'm still in "Oh, Pioneer, I've heard of them" mode. The biggest frustration I am running into is finding a compact center channel that isn't cheap enough that it makes me worry about quality. Thanks much!
