Upgrading from receiver to AMP
Discussion in 'AV Receivers' started by Clark F, Jul 11, 2003.
  1. Clark F
    Clark F Agent
    Mar 11, 2003
    45
    I have the following setup.
    Fronts - Monitor 7
    Surround - Esprit
    Center - CC-170
    Sub - PDR-10
    Receiver Yamaha RX-V630
    DVD - Panasonic RP-62
    I probably listen to music 40% and TV 60%.
    I have been thinking about further upgrades, but do not know where to go from here.
    Will adding a two channel amp for the fronts improve music quality? Would I also need a CD player (instead of the RP-62) to get improved sound?
    Can I bi-amp using the 630 and a 2 channel amp? Would bi-amping improve sound?
    TIA
  2. Clark F
    Clark F Agent
    Mar 11, 2003
    45
    Oops - posted in the wrong forum by mistake.
  3. PhilMays
    PhilMays Stunt Coordinator
    Jul 1, 2003
    53
    By adding an external amp you will vastly improve your sound quality.
    I do not think you can bi-amp using both an external and the internal amp of the Yamy as you will have to use the pre-outs on your amp to run the external amp.
    You may want to consider a good 5 channel amp that you could use in the future with a new reciever.
    I think if you could use a fiber optic cable -vs- analog cables it will greatly improve sound.
