Upgrade dvd player to Panasonic RP56
Discussion in 'Playback Devices' started by Ferdinand C, Dec 6, 2003.
  1. Ferdinand C
    Ferdinand C Auditioning
    Nov 4, 2001
    8
    Hi all-
    I'm looking to upgrade my existing RP56 dvd player since it does not play DVD +R's. In addition, I'm looking for a player that handles DVD Audio. Would the Denon 2200 or 2900 be an acceptable upgrade? My main concern is picture quality and I'm afraid that the picture quality might be worse on the Denon since these models don't use the faroujda chip. Also, don't the Denon's have the chroma issue that the RP56 does not have. Any opinions are appreciated.
    Thanks!
    Ferd
  2. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    If you want Faroudja and DVD-audio you could go with the less expensive Denon DVD-1200 model, it has both for around $399. Or the cheaper Mitsubishi DD-8040 has Faroujda and DVD-audio (seems based on the same design as the Denon DVD-1200) for around $250 at Tweeter stores.
  3. Bhagi Katbamna
    Bhagi Katbamna Supporting Actor
    Jun 1, 2000
    870
    I bought my Mitsubishi DD-8040 a few days ago for $202 including tax. I can confirm it plays DVD+R and DVD-Audio
  4. Dan Hopkinson
    Dec 15, 2000
    26
    I went from the Rp-56 to the 2200, I wasn't too concerned about picture quality. I can tell you that I don't see any appreciable difference in PQ.
