John Dunlap
- May 8, 2002
I am currently using a Rotel RSP-985 Pre/Pro with a Marantz MM-9000. When driving my Paradigm Studio 60's and Studio CC I feel that my system is a bit on the bright (harsh sounding) side. This is not really an issue with HT but more so with music. Admittedly some of this is due to room acoustics which will be solved once I finish my basement as a dedicated HT.
In the meantime I am wondering if I could do a little better than that Marantz amp that I have now. It is generously rated at 150wpc but at higher volumes it is definitely not the cleanest sounding amp I've heard. I'm considering the following options and I would like to hear some opinions. Thanks!!
1. Option 1-Sell MM-9000 and replace with an RMB-1066 whihc will be bridged to drive the L/C/R channels. I will use my old Denon to power the surrounds.
2. Option 2-Sell MM-9000 AND RSP-985 and replace with RSX-1055-new Rotel surround receiver.
3. Option 3-Sell MM-9000 and replace with B&K AV5125
