Hi all,
I have an unusual speaker question. I own a set of Midiland 5.1 speakers, they're originally designed for a computer system with 300 watt amp built into the subwoofer.
Now these things are from the computer speaker "Hey day" when Klipsch and others were releasing high quality speakers. They're very fine quality speakers.
I'd like to continue to use these in a small 5.1 setup for a single room. But I'm not sure it's possible. Unfortunately, their website is gone as is the company, so I'm going to try to describe the input/output config and maybe someone can tell me if they're usable for the new HD audio streams if I bought a new receiver?
The speakers use standard copper wiring to the amplifier which has the little "Clip-clamps". From the subwoofer, there is a very thick(about 1") wire that goes from the amp to the receiver, at the receiver end it breaks into 6 seperate RCA connectors. The subwoofer is powered.
Would this function in a modern receiver and be able to accept HD streams?
Thanks for your time!
Ry
Ry
