Unusual Black Bars with PS2 Connected to 42H80
Discussion in 'Archived Threads 2001-2004' started by Damon B, Jul 1, 2002.
  1. Damon B
    Damon B Auditioning
    Jun 17, 2002
    7
    I have my PS2 connected via Monster Components to my Toshiba 42H80. I play 2 games mostly at the moment: GT3 (16:9) and Madden Football (16:9). Anyway, I've noticed that on both games there are slight black bars on the sides of the screen. I'm running in "Full" mode which should be correct. I've verified that the games are set-up in 16:9 mode. My DVD player, which is connected to the other component inputs on the display, doesn not have this problem. Is this a PS2 issue? Or, is it a geometry issue with the display? Between the 2 games, the black bars are not similar in size. In fact, I think the bars are a lot smaller in Madden and the one on the left is almost not there.
    I hope this makes sense. I want to know if I should be contacting Best Buy to exchange my display. Maybe I should try flipping inputs with my DVD player to help isolate the problem. Any comments or advice is appreciated.
    Damon
  2. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    Have you setup your PS2 for 16x9 output in the setup menu?
  3. Damon B
    Damon B Auditioning
    Jun 17, 2002
    7
    Ack! It has a setup for this in the menu? :b I thought about that at one point but never looked into it, because I had to go. I'll try that tonight, if it does in fact have this.
  4. John Royster
    Oct 14, 2001
    1,088
    Give is a shot.
    It is in the actual setup menu of the PS2 itself. Let's home it is something that simple. [​IMG]
  5. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
    It's normal. On non-WS sets, the black bars usually get lost in the overscan.
  6. Morgan Jolley
    Morgan Jolley Lead Actor
    Oct 16, 2000
    8,964
    143
    9,110
    The PS2 menu setting for 16:9 is just for the PS2 menus, not for actual games.
    If you have a little underscan on the sides, its no big deal. As long as you see the whole image you're fine.
  7. Damon B
    Damon B Auditioning
    Jun 17, 2002
    7
    Well, apparently it is "underscan". I was just concerned, because I have been reading that watching anything with black bars for an extended period of time could risk burn-in. Kind of frustrating.... Why does the PS2 do this? So, have others noticed the same effect?
    Later
  8. Adam Tyner
    Adam Tyner Screenwriter
    Sep 29, 2000
    1,410
    Damon -- it's to compensate for overscan. That way, no important information will be lopped off the screen.
  9. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    As for burn-in, it is no different than watching 2.35 movies on a 16:9 set.
    -Dave
  10. Tony Mirra
    Tony Mirra Stunt Coordinator
    Jun 1, 2000
    194
    I have the same problem with my Gamecube on my 40H80, but it doesn't do it with the Xbox.
    Strange.
  11. Tim Markley
    Tim Markley Screenwriter
    Jun 12, 1999
    1,279
    I have the same thing on my PS2 and my XBox, but only on the left side. My TV (Mits 65907) has been properly calibrated using Avia and I have also reduced the overscan on it for DVDs using the Avia test pattern. I could adjust the TV to get rid of the black bar but then the DVDs wouldn't be 'correct' so I just leave it this way.
