Unsure how to connect 30 year old speakers with bare wires to a modern reciever
Discussion in 'Speakers' started by Seam Dempsy, Jan 1, 2004.
  1. Seam Dempsy
    Seam Dempsy Stunt Coordinator
    Dec 2, 2003
    75
    I have a pair of speakers that still work and would like to continue using, yet I am unable to connect them to a new reciever since they have only bare wires. I was wondering if there was a way through maybe an adapter that I could be able to connect them to a new reicever.
  2. Jesse Sharrow
    Jesse Sharrow Supporting Actor
    Jul 11, 2003
    745
    Yeah you can go almost anywhere, radio shack, best buy, etc. and get banana plugs or adapters that should work fine.
  3. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    You still can (As far as I know) connect bare wire to any set of binding posts. You may have to unscrew them to get access to it if you have the nice multi-way posts, or push the connector if you have the spring clip connectors.
    What receiver is it? That might aid us in giving some specific help.
  4. Seam Dempsy
    Dec 2, 2003
    75
    Its an ONKYO TX-SR501.
  5. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    Yep, you can either buy banana plug connectors, or unscrew the binding posts, shove the wire in there, and screw it back down. I have bananas on one system and bare wire on another, and other than convenience, I don't think it makes one ioda of a difference which way you do it.
