Universal Remote MX-350
Discussion in 'Accessories, Cables, and Remotes' started by BrianBbb, Sep 4, 2005.
  1. BrianBbb
    BrianBbb Agent
    Apr 1, 2004
    26
    I searched and found a ton of discussions on the Harmony but a HT installer I communicated with on another forum said that he never uses those and favors the MX-350 much more on his smaller jobs. I'm not findig much information on these. Reviews, discussions, etc.
    anybody have any experience with them?
  2. BrianBbb
    BrianBbb Agent
    Apr 1, 2004
    26
    ok I am finding some stuff on them now. specifically the forum at remote central.com. also some discussion here but that seems to mostly about the MX-500 model. anyways if anyone has experience with boith, I'd like to hear about them.
    thanks
  3. Stephen Tu
    Stephen Tu Screenwriter
    Apr 26, 1999
    1,573
    MX-350 vs. MX-500:
    advantages:
    -many more, longer macros available
    -RF with addressable base stations, base station is extra cost
    -better directional pad with separate select button
    -no dual labeled keys, less confusing for new users
    -more total commands supported
    disadvantages:
    -cost
    -fewer commands per LCD page, 5 vs. 10
    -missing chapter skip buttons
    vs. Harmony:
    advantages:
    -overall better feel, size, placement of buttons
    -real macros available, not just "activities".
    -can tweak programming without hooking up to computer + internet
    disadvantages:
    -not computer programmable, so may need another cheap OneForAll JP-1 compatible remote to obtain discrete codes for reliable macro operation.
    -no "smart state" to deal with devices without discrete codes for on/off, input selection.
    You should also consider the MX-700 which can be found for about the same price as the MX-350. It offers computer based programming, and has the 10-command LCD.
